The AC1200 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own, achieving speeds of 300Mbps on the 2.4GHz band and 867Mbps on the 5GHz band.
Product Description | TP-Link RE365 - Wi-Fi range extender - Wi-Fi 5 | Device Type | Wi-Fi range extender | Form Factor | External | Localisation | France | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | OS Required | UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8 | Dimensions (WxDxH) | 7 cm x 7.7 cm x 12.5 cm | Manufacturer Warranty | 3-year warranty |
General | |
Width | 7 cm |
Depth | 7.7 cm |
Height | 12.5 cm |
Networking | |
Connectivity Technology | Wireless, wired |
Data Transfer Rate | 1.2 Gbps |
Wi-Fi Rating | AC1200 |
Status Indicators | Power |
Features | Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 8 Watt |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
