We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | TP-Link RE605X - Wi-Fi range extender - Wi-Fi 6 | Device Type | Wi-Fi range extender | Form Factor | In-wall mountable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax | Frequency Band | 2.4 GHz, 5 GHz | Dimensions (WxDxH) | 74 mm x 46 mm x 124.8 mm | Weight | 220 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 74 mm |
Depth | 46 mm |
Height | 124.8 mm |
Weight | 220 g |
Networking | |
Connectivity Technology | Wireless, wired |
Line Coding Format | 1024 QAM, OFDMA |
Features | Wi-Fi Protected Setup (WPS), MU-MIMO technology, OneMesh support |
Encryption Algorithm | WPS |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6 |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Power | |
Power Device | Internal power supply |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
