TP LINK Tapo C100 Spot Cam
£29.98
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Motion detection
  • Night vision
  • High-definition video
  • Two-way audio
  • Protect your privacy
  • Privacy mode
  • Type: Indoor Camera
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (4)
KASA STARTER KIT - BULBS AND SMART PLUGS
= £79.97
Save £30.00
GOOGLE NEST HUB MAX
GOOGLE NEST HUB MAX
= £178.98
Save £20.00
KASA SMART POWER STRIP
= £54.96
Save £5.00
NEST MINI
NEST MINI
= £49.98
Save £3.99
When you are away home, there are always something you care about. This is where the smart camera functions. No matter your child is climbing the kitchen cabinet, or the pet is stealing snacks, Tapo C100 helps you stay with them anytime, anywhere.
Receive a notification whenever your camera detects motion and see a video clip of the motion for closer inspection. Also, you can personalize your own experiences by setting the motion detection zones to only capture what happens in the area that you choose.
Product Description Tapo C100 - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 6.76 cm x 5.48 cm x 9.89 cm
Connectivity Technology Wireless
Camera Colour - Day&Night
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/3.2"
Focal Length Control Fixed focal
Focal Length 3.3 mm
Lens Iris F/2.0
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage DC 9 V
Features Alarm function, ONVIF support, Privacy mode, Push Notification, reset button, WPA, WPA2-PSK, WEP
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Tapo C100 Spot...
£29.98
