2,700 K Warm Light- Set off a cozy and comfortable vibe for your home or any other public space
1~100% Dimmable - Dim to any brightness you desire for constantly-changing needs.
High Lumen - Emits 350 lm light that is bright enough to shed light on any object
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your Smart Spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup & Use - No hub required, set up quickly and manage easily through the free App.
Product Description | Tapo L610 - LED spot light bulb - GU10 - 2.9 W - warm white light - 2700 K (pack of 2) | Light Source Type | LED spot light bulb | Packaged Quantity | 2 (specifications are for single item) | Usage Modes | Energy save | Socket Type | GU10 | Wattage | 2.9 W | Wattage Equivalent | 50 W | Energy Efficiency Class | D | Colour of Illumination | Warm white light | Colour Temperature | 2700 K | Luminous Power | 350 lumens | Beam Angle | 40 degree(s) | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
General | |
Light Source | |
Wattage | 2.9 W |
Energy Consumption per 1000h | 3 kWh |
Colour Rendering Index | 80 |
Warm-Up Time | 1 sec |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 15000 |
Features | 1%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology |
Power Requirements | |
Power Consumption Stand by | 0.2 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Compatible Application | Tapo app |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Compliant Standards | RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Dimensions & Weight | |
Height | 5.52 cm |
Diameter | 5 cm |
Shipping Dimensions (WxDxH) / Weight | 51 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
