TP LINK Tapo L630 GU10 Smart Bulb (colour) 4-Pack
17 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
  • Type: Light bulb
  • Compatible With: Alexa
Product codes
16 Million Colours -Shape the amazing vibe by picking the lights from a wide array of colours, even dim to any brightness you desire for the perfect atmosphere.
White Tuneable - Adjust the colour temperature from 2,200 K to 6,500 K based on your changing needs.
High Lumen & Dimmable - Emits 350 lm light that is bright enough to shed lights on any object and could be dimmed from 1% to 100%.
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App.
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your smart spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup and Use - No hub required, set up quickly and manage easily through the free App
Product Description Tapo L630 - LED spot light bulb - GU10 - 3.7 W - 16 million colours/tunable white - 2200-6500 K (pack of 4)
Light Source Type LED spot light bulb
Packaged Quantity 4 (specifications are for single item)
Usage Modes Energy save
Socket Type GU10
Wattage 3.7 W
Wattage Equivalent 50 W
Energy Efficiency Class E
Colour of Illumination 16 million colours/tunable white
Colour Temperature 2200-6500 K
Luminous Power 350 lumens
Beam Angle 40 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Voltage Required AC 220 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£29.98
