Marketing description is not available.
Product Description | Tapo L930-5 - light strip - LED - 13 W - 16 million colours | Product Type | Light strip | Light Source Type | LED | Usage Modes | Away | Wattage | 13 W | Colour of Illumination | 16 million colours | Luminous Power | 1000 lumens | Dimmable | Yes | Intelligent Assistant | Siri, Google Assistant, Alexa - indirect | Platform | Apple HomeKit | Communications Technology | Wi-Fi | Voltage Required | AC 100 - 240 V | Frequency Required | 50/60 Hz |
General | |
Features | Flexible, remote controlled, 3M adhesive tape mounting, cuttable, app-controlled, lighting schedules, Wi-Fi (2.4 GHz) controlled, power on/off timer, voice control, 50 colour zones |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 13 W |
Dimmable | Yes |
Lifetime | 50000 hours |
Features | 1%-100% dimmable, music sync, white LED, preset modes |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Compatible Application | Tapo app |
Intelligent Assistant | Siri, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Polyurethane (PU) |
Compliant Standards | VCCI, BSMI, IC, FCC, RoHS, NCC, RCM, JRF, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Dimensions & Weight | |
Width | 1 cm |
Height | 0.3 cm |
Length | 5 m |
Weight | 649 g |
Shipping Dimensions (WxDxH) / Weight | 23.15 cm x 6.85 cm x 20.45 cm |
Environmental Parameters | |
Min Operating Temperature | -15 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
