TP LINK Tapo S210 Smart Light Switch 1Gang 1Way
PRICE DROP
RRP £19.99
£20.00
Delivery:
Standard: 1-3 working days
Key features
  • Hub Required
  • Type: Wireless light switch
  • Compatible With: Alexa, Google Assistant
Product codes
Remote Control
Instantly turn the light on/off wherever you are through the Tapo app.
Voice Control
Manage your switch with voice commands via Amazon Alexa or the Google Assistant.
Schedule
Preset a schedule to automatically manage devices.
Away Mode
Automatically turn the light on and off at different times to give the appearance that someone is home.
Tool-Free Battery Replacement
Easily replace batteries after installation, no need of other tools.
No Neutral Wire Required
Super easy wiring. No neutral wire required.
Hub Required
The Tapo Hub is required to support all smart features.
Enhanced Experience with Smart Actions
With Smart Acitons, your Tapo devices work seamlessly together to create a smarter home. Trigger your switch when motion is detected with the Tapo Motion Sensor.
Part of the Tapo Ecosystem
To experience the full features of your Tapo, connect it to a Tapo Hub (H100) for a truly connected home. Group lights and devices onto one switch to control the entire room with a single tap.
Product Description Tapo S210 V1 - light switch - smart
Product Type Light switch
Gangs Qty 1
Functions Light control
Power Source Battery
Internet of Things (IoT) Platform Tapo
Intelligent Assistant Google Assistant, Alexa - indirect
Connectivity Wireless
Frequency Band 868 MHz
Dimensions (WxDxH) 8.6 cm x 4.1 cm x 8.71 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£20.00
