Remote Control
Instantly turn the light on/off wherever you are through the Tapo app.
Voice Control
Manage your switch with voice commands via Amazon Alexa or the Google Assistant.
Schedule
Preset a schedule to automatically manage devices.
Away Mode
Automatically turn the light on and off at different times to give the appearance that someone is home.
Tool-Free Battery Replacement
Easily replace batteries after installation, no need of other tools.
No Neutral Wire Required
Super easy wiring. No neutral wire required.
Hub Required
The Tapo Hub is required to support all smart features.
Enhanced Experience with Smart Actions
With Smart Acitons, your Tapo devices work seamlessly together to create a smarter home. Trigger your switch when motion is detected with the Tapo Motion Sensor.
Part of the Tapo Ecosystem
To experience the full features of your Tapo, connect it to a Tapo Hub (H100) for a truly connected home. Group lights and devices onto one switch to control the entire room with a single tap.
Product Description | Tapo S220 V1 - light switch - smart | Product Type | Light switch | Gangs Qty | 2 | Functions | Light control | Power Source | Battery | Internet of Things (IoT) Platform | Tapo | Intelligent Assistant | Google Assistant, Alexa - indirect | Connectivity | Wireless | Frequency Band | 868 MHz | Manufacturer Warranty | 2-year warranty | Dimensions (WxDxH) | 8.6 cm x 4.1 cm x 8.71 cm |
General | |
Gangs Qty | 2 |
Lamp Compatibility | LED lamp, incandescent lamp, Compact Fluorescent Lamp (CFL), Fluorescent Tube Light (FTL) |
Maximum Loads | LED lamp - 600 W , Compact fluorescent lamp - 600 W , Incandescent lamp - 1000 W , Fluorescent tube light - 1000 W , Fan - 50 W |
Connectivity Technology | Wireless |
Features | Away Mode, remote access, voice control, timer, 1-way switch, schedule function, no neutral required, low-battery reminder |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Required |
Hub Compatibility | Tapo Hub |
Platform | Tapo |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Battery | |
Form Factor | AAA / LR03 |
Battery Included | Yes |
Required Qty | 2 |
Voltage Provided | 1.5 V |
Battery Lifetime | 1 year |
Miscellaneous | |
Included Accessories | 2 mounting screws, 2 AAA batteries |
Compliant Standards | RoHS, UKCA |
Dimensions & Weight | |
Width | 8.6 cm |
Depth | 4.1 cm |
Height | 8.71 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% RH (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
