TP-LINK's TD-W8961N 300 Mbps Wireless N ADSL2+ Modem Router is an incredibly robust all-in-one device that provides a full rate of ADSL2+ standard with the superb reliability and a cost-effective solution for home and small business. With the TD-W8961N, you can easily create a secure wireless network and share a high-speed Internet connection while access to shared files, music, photos, and printers with multiple computers.
Product Description | TP-Link TD-W8961N - wireless router - DSL modem - 802.11b/g/n - desktop | Device Type | Wireless router - DSL modem - 4-port switch (integrated) | Enclosure Type | Desktop | Digital Signaling Protocol | ADSL, ADSL2, ADSL2+ | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | Capacity | Permanent virtual circuits (PVC): 8 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS, DDNS | Routing Protocol | RIP-1, RIP-2, static IP routing | Remote Management Protocol | SNMP 1, Telnet, IPP, SNMP 2c, HTTP | Features | DMZ port, NAT support, VLAN support, IGMP snooping, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, MAC address filtering, URL filtering, IP address filtering, firmware upgradable, Access Control List (ACL) support, Quality of Service (QoS), virtual server support, IPSec passthrough, DHCP relay, DNS relay, application filtering, SYN Flooding, Ping of Death, proxy firewall, Type of Service (ToS), DiffServ Code Point (DSCP) support | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP | Dimensions (WxDxH) | 19.5 cm x 13 cm x 3.5 cm | System Requirements | UNIX, Apple MacOS, Linux, Windows 8, Microsoft Windows 98SE/2000/NT/XP/Vista/7 |
General | |
Device Type | Wireless router - 4-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, SSL, WPA, WPA2-PSK |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS |
Line Properties | |
Framing Format | ANSI T1.413 |
Communications | |
Type | DSL modem |
Protocols & Specifications | ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1 |
Expansion / Connectivity | |
Interfaces | LAN: 4 x Ethernet 10/100 - RJ-45 , Phone line: 1 x ADSL2+ - RJ-11 |
Aerial | |
Aerial | External integrated |
Antenna Qty | 2 |
Directivity | Omni-directional |
Gain Level | 5 dBi |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Included Accessories | ADSL splitter |
Cables Included | 1 x phone cable , 1 x network cable |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | UNIX, Apple MacOS, Linux, Windows 8, Microsoft Windows 98SE/2000/NT/XP/Vista/7 |
Dimensions & Weight | |
Width | 19.5 cm |
Depth | 13 cm |
Height | 3.5 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
