TP LINK TD-W9960 300Mbps Wi-Fi VDSL/ADSL Modem Router
£25.41
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Versatile connectivity: with DSL and LAN/WAN ports, TD-W9960 is fully compatible with the VDSL2/ADSL2+/ADSL2/ADSL standards and also works with fiber/cable access
  • Boosted speeds: superfast VDSL broadband speeds of up to 100Mbps together with 300Mbps Wi-Fi
  • Maximized range: powerful external antennas provide far-reaching wireless coverage in every direction
  • Effortless management: set up in minutes with the powerful Tether app or intuitive web interface and manage the network from anywhere
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
  • Speed: 300Mbps
  • Stock Status: In Stock
Product codes
VDSL2 technology delivers VDSL broadband speeds of up to 100Mbps simultaneously in both the upstream and downstream directions. The integrated DSL port supports all standard DSL connections for compatibility with most ISPs.
With 300Mbps wireless speeds on the 2.4GHz band and 4 megabit LAN ports, the TD-W9960 is perfect for streaming in HD, online gaming and other bandwidth-intensive applications.
Set up the TD-W9960 in minutes thanks to its intuitive web interface and the powerful Tether app. Manage network settings, including Parental Controls and Access Control, from any Android or iOS device. Control your home network whenever and wherever you are.
Two external 5dBi high-gain antennas beam signal to every corner of your home, creating a strong, stable Wi-Fi network.
Lightning protection shields TD-W9960 from electrical damage caused by thunderstorms, so even in bad weather, you can enjoy internet with peace of mind.
Parental Controls limit the online time and access of specified devices. Guest Network creates a separate Wi-Fi network for visitors, keeping your main network secure.
Product Description TP-Link TD-W9960 - wireless router - DSL modem - 802.11b/g/n - desktop
Device Type Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type Desktop
Digital Signaling Protocol ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Data Transfer Rate 300 Mbps
Network / Transport Protocol PPPoE, PPPoA, IPoA, IPoE
Routing Protocol IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol HTTP, TR-069
Features Firewall protection, DMZ port, NAT support, ALG support, IPv6 support, VPN passthrough, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button, bandwidth control, IPv4 support, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, Denial of Service (DoS), SYN Flooding, Ping of Death, port mapping
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
Dimensions (WxDxH) 18.16 cm x 12.97 cm x 3.62 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK TD-W9960 300Mb...
£25.41
