TP LINK TL-MR6400 300Mbps Wireless N 4G LTE Router
£93.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Share your 4G LTE network with multiple Wi-Fi devices and enjoy download speeds of up to 150 Mbps
  • Wireless N speeds of up to 300 Mbps
  • Integrated antennas provide stable wireless connections
  • Requires no configuration - just insert a SIM card and turn it on to enjoy high-speed Internet access
  • LAN/WAN port provides flexibility, allowing you to choose your connection type
Product codes
Take full advantage of your 4G LTE network with the TL-MR6400, which can achieve download speeds of up to 150 Mbps. The TL-MR6400 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do insert a SIM card and turn the router on. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
TP-Link TL-MR6400 - wireless router - WWAN - 802.11b/g/n - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DoS attack prevention, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, reset button, IPv4 support, Stateful Packet Inspection Firewall (SPIF), DHCP client
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
20.2 cm x 14.1 cm x 3.36 cm
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK TL-MR6400 300M...
£93.62
