Plug and Play, No Configuration
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the router. Enjoying fast, stable WiFi on a 4G LTE network has never been easier.
Enjoy WiFi and Phone Calls Simultaneously
TL-MR6500v is not only a WiFi router and modem combo, but also a phone. It has a phone port to connect your existing landline phone so that you can make phone calls and surf the internet at the same time. Moreover, various voice functions are supported including VoIP, VoLTE, and CSFB. Simply enjoy a professional and high-quality voice call as you like.
Special Design for Maximum Network Coverage
Two detachable advanced antennas reinforce the wireless connection between the router and every device with more stability and flexibility. A built-in power amplifier and low noise amplifier also help provide wider coverage by improving the router’s sending and receiving capabilities.
Product Description | TP-Link TL-MR6500V - V1 - wireless router - WWAN - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - wireless cellular modem - 3-port switch (integrated) | Enclosure Type | Desktop | Mobile Communication Protocol | UMTS, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 300 Mbps | Performance | Channel bandwidth (2.4 GHz): 300 Mbps , Channel bandwidth (5 GHz): 867 Mbps | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, IPv4, IPv6 | Routing Protocol | Static IP routing | Features | DHCP support, Stateful Packet Inspection (SPI), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, port forwarding, reset button, port triggering, IP-MAC binding, DHCP client, Denial of Service (DoS), DHCP reservation, Wireless Scheduler, domain filter, dual band, DMZ support, DynDNS, WPS button, 3G/4G router mode | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac | Dimensions (WxDxH) | 17.4 cm x 12.45 cm x 3.35 cm | System Requirements | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10 |
General | |
Device Type | Wireless router - 3-port switch (integrated) |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, Plug and Play, RoHS |
Communications | |
Type | Wireless cellular modem |
Data Compression Protocol | RFC3261, RFC3550, RFC1889 |
IP Telephony | |
Voice Codecs | G.729ab, G.726, G.711A/µ |
Expansion / Connectivity | |
Interfaces | LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 |
Expansion Slots | 1 (total) / 1 (free) x Micro-SIM |
Aerial | |
Aerial | External detachable |
Antenna Qty | 2 |
Power | |
Power Device | External power adapter |
Installed Qty | 1 |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10 |
Dimensions & Weight | |
Width | 17.4 cm |
Depth | 12.45 cm |
Height | 3.35 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
