TP LINK TL-PB10400 10400mAh Power Bank
PRICE DROP - WAS £24.37!
£28.57
Delivery:
Standard: 1-3 working days
Key features
  • High capacity of 10400 mAh
  • Dual USB ports let you quickly charge two devices simultaneously
  • Compatible with 5 V input USB-charged devices
  • Multiple safety protections
  • Practical flashlight
Product codes
Powerful Capacity
Powerful capacity of 10400mAh lets you charge a smartphone 3~5 times, keeping your devices running all the time.
* Actual number of charge times depends on your device's battery size.
Simultaneously Super-fast Charging
Dual USB ports (5V/2A and 5V/1A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones.
Reliable Power
TL-PB10400's multiple protections of short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating ensure safe and reliable charging to avoid any potential harm to your devices.
High Energy Efficiency Rate
Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3~5 times, ideal for extended use of mobile devices.
Practical Functions for Convenience
Smart LED Indicator: Four LED lights work as charge indicators to show battery level or charging status
Practical Flashlight: Built-in flashlight comes in handy for in-house and off-road activities
Universal Compatibility
Compatible with almost any smart devices like iPhones, iPads, Android smartphones and other 5V input USB-charged devices.
TP-Link TL-PB10400 - power bank
Power bank
4.43 cm x 4.43 cm x 8.88 cm
241 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
- 10400 mAh
Cables
Micro-USB cable
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK TL-PB10400 104...
£28.57
