TP LINK TL-R480T+ Up to 4 WAN ports Load Balance Broadband Ro...
TP LINK TL-R480T+ Up to 4 WAN ports Load Balance Broadband Router
£55.89
Delivery:
Standard: 1-3 working days
Key features
  • Shares data and Internet access for Stations, connecting Internet through PPPoE on demand and disconnecting when idle
  • Supports TCP/IP, PPPoE, DHCP, ICMP, NAT, SNTP
  • Provides double-bandwidth access and supports load balancing
  • Backup's connections automatically for each other
  • Specifies priority channels according to source or destination IP addresses, distributing flexibly Internet resource and services from different ISPs
  • Built-in NAT and DHCP server supporting static IP address distributing
  • Built-in firewall supporting IP address filtering, domain name filtering, and MAC address filtering
  • Supports UPnP, static routing, VPN pass-through
  • Supports connecting/disconnecting Internet on a specified time of day
  • Supports access control based on time of day, parents and network administrators can establish restricted access policies for children or staffs
  • Supports Web-based firmware upgrade
  • Supports remote and Web management
  • Type: Router
  • Connection Type: DSL (Cable)
  • Standards: Ethernet, Fast Ethernet
  • Stock Status: In Stock
Product codes
The TL-R480T+ adopts Intel IXP network processors, main frequency up to 266MHz, multi-CPU distributed architecture, to ensure high performance and high availability. Additionally, the 6-layer PCB, the built-in high-redundancy power module feature a architecture that dramatically stretches the performance of the router by enabling stable connections.
The TL-R480T+ features two WAN ports, which allows two connections to the Internet at the same time, provides you double-bandwidth access, and gives you the ability to enjoy more Internet sources from different ISPs. With fail-over and automatic load balancing, no manual work should ever be required.
The TL-R480T+ provides all the normal settings of a broadband router, it features much more advanced functions, such as Bandwidth Control, Port Mirror, Port VLAN, UPnP, VPN Pass-through, Firewall, System Log and so on.
The TL-R480T+ provides a friendly configuration interface for easy using. With multiple functions, high-reliability, and high-security, it widely meets enterprise, organ, Internet cafe, broadband community, and school networks new and changing requirements.
Product Description TP-Link TL-R480T+ - router - desktop
Device Type Router - 3-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 2
Data Link Protocol Ethernet, Fast Ethernet
Network / Transport Protocol TCP/IP, PPPoE
Routing Protocol Static IP routing
Remote Management Protocol HTTP
Features Firewall protection, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), DoS attack prevention, port mirroring, MAC address filtering, VPN passthrough, firmware upgradable, virtual server support, DHCP server
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 29.4 cm x 18 cm x 4.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK TL-R480T+ Up t...
£55.89
