TP LINK TL-SF1005P 5-Port 10/100 Mbps Desktop Switch
£30.30
Delivery:
Key features
  • 5 10/100Mbps RJ45 ports
  • With four PoE ports, transfers data and power on one single cable
  • Working with IEEE 802.3af compliant PDs, expands home and office network
  • Supports PoE Power up to 15.4W for each PoE port
  • Supports PoE Power up to 58W for all PoE ports
  • Requires no configuration and installation
Product codes
TL-SF1005P is a 5 10/100Mbps ports unmanaged switch that requires no configuration and provides 4 PoE (Power over Ethernet) ports. It can automatically detect and supply power with all IEEE 802.3af compliant Powered Devices (PDs). In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network to where there are no power lines or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones, etc.
Product Description TP-Link TL-SF1005P - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Fast Ethernet
Ports 5 x 10/100 (4 PoE)
Power Over Ethernet (PoE) PoE
PoE Budget 58 W
Performance Switching capacity: 1 Gbps
MAC Address Table Size 2K entries
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
Dimensions (WxDxH) 9.98 cm x 9.8 cm x 2.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK TL-SF1005P 5-P...
£30.30
