The TP-Link 16-port 10/100/1000Mbps Desktop Switch provides you an easy way to make the transition to Gigabit Ethernet. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Plug and Play design, with no configuration required, makes the product easy to use. Moreover, TL-SG116 adopts lower power consumption design. With the innovative energy-efficient technology, the TL-SG116 can save power consumption, making it an eco-friendly solution for your home or office network.
Product Description | TP-Link TL-SG116 - switch - 16 ports | Device Type | Switch - 16 ports | Subtype | Gigabit Ethernet | Ports | 16 x 10/100/1000 | Performance | Packet forwarding rate: 23.8 Mpps | MAC Address Table Size | 8K entries | Jumbo Frame Support | 10KB | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, fanless | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x | Dimensions (WxDxH) | 28.6 cm x 11.17 cm x 2.54 cm |
General | |
Enclosure Type | Desktop |
Expansion / Connectivity | |
Interfaces | 16 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 10 Watt |
Miscellaneous | |
Included Accessories | Rubber feet |
Compliant Standards | FCC, RoHS |
Dimensions & Weight | |
Width | 28.6 cm |
Depth | 11.17 cm |
Height | 2.54 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
