TP LINK TL-SL1226P 24-Port 10/100 Mbps + 2-Port Gigabit Rack...
TP LINK TL-SL1226P 24-Port 10/100 Mbps + 2-Port Gigabit Rack Switch
£176.92
Delivery:
Standard: 1-3 working days
Key features
  • 24x PoE+ 10/100 Mbps RJ45 ports, 2x Gigabit RJ45 ports, and 2x combo Gigabit SFP slots
  • High PoE power budget with up to 30 W for each PoE port and 250 W for all PoE ports
  • Up to 250 m data and power PoE transmission range under Extend Mode, ideal for surveillance system
  • Priority Mode ensures high priority of ports 1 - 8 to guarantees the quality of sensitive applications like video monitor
  • Isolation Mode allows one-click client traffic separation for higher security and performance
  • Plug and play, with no configuration and installation needed
  • Type: Fast Ethernet
  • Ports: 26
  • Managed: No
  • POE: PoE+
Product codes
TP-Link's new PoE/PoE+ switches with all 10/100 Mbps RJ45 ports supporting the PoE+ standard provides a simple way to expand the wired network while transferring power over the same Ethernet cable at the same time. With up to 30 W per port TL-SL1226P can power more high-powered devices such as Access Points, IP Cameras, IP Phones and so on. Moreover, with innovative Extend Mode, devices can get PoE power supply and data transmission from a distance of 250 m. Priority mode ensures high priority for port 1 - 8, which guarantees the quality of sensitive applications. TL-SL1226P supports Isolation Mode that divides traffic for ports 1 - 24 for higher security and performance.
Product Description TP-Link TL-SL1226P - switch - 26 ports - unmanaged - rack-mountable
Device Type Switch - 26 ports - unmanaged
Enclosure Type Rack-mountable 1U
Subtype Fast Ethernet
Ports 24 x 10/100 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 250 W
Performance Switching capacity: 8.8 Gbps , Packet forwarding rate: 6.54 Mpps
Capacity Packet buffer size: 4.1 Mbit
MAC Address Table Size 8K entries
Jumbo Frame Support 10KB
Features Flow control, power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, PoE+, 2 fans, MAC address learning, MAC address aging, priority mode, extend mode, security slot (Kensington security lock compatible)
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 18 cm x 4.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£176.92
