With L5350E and the Tapo app, you just need one tap on your smart phone, then everything is on. No matter how late you arrive home ,Tapo is always there. Welcome home!
Connect the L530E Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices. Advanced technology allows Tapo L530 to use less energy than normal LED lights - only 8.7 W for 806 lm (60 W equivalent).
Product Description | Tapo L530E - LED light bulb - E27 - 8.7 W - 16 million colours - 2500-6500 K (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Usage Modes | Sunrise, sunset, away | Socket Type | E27 | Wattage | 8.7 W | Wattage Equivalent | 60 W | Energy Efficiency Class | F | Colour of Illumination | 16 million colours | Colour Temperature | 2500-6500 K | Luminous Power | 806 lumens | Beam Angle | 220 degree(s) | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Tapo | Communications Technology | Wi-Fi | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
General | |
Light Source | |
Socket Type | E27 |
Wattage | 8.7 W |
Energy Consumption per 1000h | 8.7 kWh |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 15000 |
Features | Voice control, controlled via Wi-Fi, light scheduling, app-controlled |
Power Requirements | |
Power Consumption Stand by | 0.5 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Platform | Tapo |
Compatible Application | Tapo app |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 115 mm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
