TP LINK TP-Link Tapo Smart WiFi Light Bulb Multicolour 2 pack
PRICE DROP
USUALLY £23.99, SAVE £8
£23.98
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Multicolor
  • 60-watt equivalent
  • Preset for convenience
  • Schedule & timer
  • Sunrise and sunset modes
  • No hub required
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
Product codes
With L5350E and the Tapo app, you just need one tap on your smart phone, then everything is on. No matter how late you arrive home ,Tapo is always there. Welcome home!
Connect the L530E Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices. Advanced technology allows Tapo L530 to use less energy than normal LED lights - only 8.7 W for 806 lm (60 W equivalent).
Product Description Tapo L530E - LED light bulb - E27 - 8.7 W - 16 million colours - 2500-6500 K (pack of 2)
Light Source Type LED light bulb
Packaged Quantity 2 (specifications are for single item)
Usage Modes Sunrise, sunset, away
Socket Type E27
Wattage 8.7 W
Wattage Equivalent 60 W
Energy Efficiency Class F
Colour of Illumination 16 million colours
Colour Temperature 2500-6500 K
Luminous Power 806 lumens
Beam Angle 220 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Platform Tapo
Communications Technology Wi-Fi
Voltage Required AC 220 - 240 V
Frequency Required 50/60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£23.98
