We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
UB400 turns Non-Bluetooth PC or laptop into Bluetooth-capable. Just connect your Bluetooth devices to your computer and enjoy it with ease. A sleek, ultra-small design means you can insert the Nano adapter into any USB port and simply keep it there, no matter when you are traveling or at home. With a transmission distance of up to 10 m, you can enjoy lossless music via your Bluetooth headset without hovering around your computer.
Product Description | TP-Link UB400 - network adapter - USB 2.0 | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Dimensions (WxDxH) | 1.48 cm x 0.68 cm x 1.89 cm | Data Link Protocol | Bluetooth 4.0 | Compliant Standards | Bluetooth 1.1, Bluetooth 2.0, USB 2.0, Bluetooth 2.1, Bluetooth 3.0, Bluetooth 4.0 | System Requirements | Microsoft Windows XP/ 7 / 8 / 8.1 / 10 |
General | |
Networking | |
Connectivity Technology | Wireless |
Features | USB powered |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows XP/ 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 1.48 cm |
Depth | 0.68 cm |
Height | 1.89 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
