TP LINK UH700 USB 3.0 7-Port Hub
£32.70
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 ports offer transfer speeds of up to 5Gbps
  • 7 data transfer ports make switching between devices unnecessary
  • Supports hot plugging
  • No driver required
  • Plug and Play
  • Type: USB Hub
  • Ports: 7
  • Stock Status: In Stock
Product codes
The UH700 USB Hub is a great choice to expand the USB ports of your computer for data transfer when you need to connect USB drives, USB mice, printers or other devices simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than USB 2.0.
High Speed Data Transfer
Equipped with USB 3.0 ports, UH700 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0.
Greatly Expand Your USB Ports
UH700 adds PC 7 additional USB ports to your PC, making it unnecessary to switch between devices.
Safe and Reliable
UH700's multiple protections avoid any potential harm to your connected devices no matter you're transferring data or charging devices.
Product Description TP-Link UH700 - hub - 7 ports
Device Type Hub - 7 ports
Ports 7 x SuperSpeed USB 3.0
Compliant Standards USB 2.0, USB 3.0
Dimensions (WxDxH) 16.5 cm x 6.55 cm x 1.75 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK UH700 USB 3.0...
£32.70
