TP LINK UH720 USB 3.0 7-Port Hub with 2 Charging Ports
£39.26
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than normal USB 2.0
  • 7 data transfer ports make switching between devices unnecessary
  • Two exclusive 2.4A charging ports supply enough current for all kinds of mobile devices
  • Intelligently adjusts the output current to match the maximum need of different devices
  • Type: USB Hub
  • Ports: 7
  • Stock Status: In Stock
Product codes
The UH720 USB Hub is a great choice to expand the USB ports of your computer for data transfer when you need to connect USB drives, USB mice, printers or other devices simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than USB 2.0. Featuring two exclusive 5V 2.4A charging ports, the hub is able to satisfy the demands of all your mobile devices.
High Speed Data Transfer
Equipped with USB 3.0 ports, UH720 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0.
Greatly Expand Your USB Ports
UH720 adds PC 7 additional USB ports to your PC, making it unnecessary to switch between devices.
Super-fast, Smart Charging
Two exclusive 2.4A charging ports supply enough current for all kinds of mobile devices. The intelligent chip recognizes connected devices and adjusts the power to match output, allowing you to charge any device at full speed.
Safe and Reliable
UH720's multiple protections avoid any potential harm to your connected devices no matter if you're transferring data or charging devices.
Product Description TP-Link UH720 - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 7 x SuperSpeed USB 3.0
Features Hot swap module replacement
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 16.5 cm x 6.55 cm x 1.75 cm
System Requirements Linux, Apple MacOS X, Microsoft Windows
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK UH720 USB 3.0...
£39.26
