TP LINK USB 3.0 4-Port Portable Hub
£13.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than standard USB 2.0
  • The 4 data transfer ports mean you don't have to switch between devices
  • Type: USB Hub
  • Ports: 4
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £16.99
Save £1.50
The UH400 USB Hub supports all USB devices including USB drives, mice, printers or any other USB device you want to run simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than the USB 2.0 standard. Equipped with USB 3.0 ports, UH400 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0. UH400 adds 4 additional USB ports to your PC, making it unnecessary to switch between devices. Compact design with a retractable cable makes it an ideal USB HUB on the go. UH400's multiple protections avoid any potential harm to your connected devices no matter you're transferring data or charging devices.
Product Description TP-Link UH400 - hub - 4 ports
Device Type Hub - 4 ports
Ports 4 x SuperSpeed USB 3.0
Compliant Standards USB 2.0, USB 3.0
Dimensions (WxDxH) 7.1 cm x 7.1 cm x 1.66 cm
System Requirements Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK USB 3.0 4-Port...
£13.50
