TP LINK Wireless N Access Point
£20.72
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Wireless N speed up to 300Mbps makes it ideal for high bandwidth consuming or interruption sensitive applications like video streaming, online gaming and VoIP
  • 2T2R MIMO technology provides robust high-bandwidth wireless Tx/Rx capability at further range
  • CCA improves wireless performance while automatically avoiding channel conflict
  • Easily setup a WPA encrypted secure connection at a push of the QSS button
  • Supports Wi-Fi Multimedia (WMM) assures the quality of VoIP and multimedia streaming
  • Supports multiple operating modes (Access Point, Client, Universal/WDS Repeater, Point to Point, Point to Multi-point)
  • Supports up to 30 meters of Power over Ethernet capability for flexible performance
  • Up to 4 SSIDs and VLAN support, it allows networks administrator to segregate different services or applications to different designated users
  • WPA/WPA2 encryptions provide your network with active defense against security threats
  • Detachable antenna allows for stronger antenna upgrades
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Compatibility: PC
Product codes
What This Product Does
The TP-LINK Wireless N Access Point TL-WA801ND is designed to establish or expand a scalable high-speed wireless N network or to connect multiple Ethernet enabled devices such as game consoles, digital media adapters, printers, or network attached storage devices to a wireless network. The APs support a host of different functions that makes your wireless networking experience more flexible than ever before. Now, you can enjoy a better Internet experience when downloading, gaming, video streaming or with any other application that you may wish to use.
Wireless N - Speed & Range
Adopting IEEE 802.11n advanced MIMO (Multi Input Multi Output) technology, it simultaneously works through two antennas to Tx and Rx to overcome the interference and signal degradation when traveling long distances or through physical barriers in a small office or a large apartment, resulting in an incredible improvement in the wireless performance, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection where legacy 11g products may not!
Multiple Operating Modes - Easy to Build WLAN
Supports AP Client, Bridge, Repeater and AP operation modes to enable various wireless applications to give users a more dynamic and comprehensive experience when using their AP. Multiple operating mode also helps you easily to build wireless network for hard-to-wire locations or eliminating wireless dead zone.
QSS Button - Quick Setup Security
Compatible with WI-FI Protected Setup™ (WPS), TL-WR801ND features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the "QSS" button automatically establishing a WPA2 secure connection, which is more security compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
PoE Supported- More Flexible Deployment (Passive PoE only - requires PSU and injector, NOT PoE capable switch)
The TL-WA801ND is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP may be located even up to 100 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
WPA / WPA2 Encryptions - Advanced Security
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside threats. TL-WR801ND provides WPA/WPA2 encryptions (Both Personal and Enterprises) that are created by the WI-FI Alliance industry group, promoting interpretabilities and security for WLAN.
Product Description TP-Link TL-WA801ND 300Mbps Access Point - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Included Accessories PoE injector
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 17.4 cm x 12 cm x 2.9 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Wireless N Acc...
£20.72
