TP LINK WLAN-Antenna 2.4GHz 14dBi Outdoor Yagi SMA
£57.48
Delivery:
Key features
  • Complies with 2.4GHz 802.11b/g standards
  • Provides 1m extension cable
  • Complete plug and play instructions
  • Works with all the wireless devices with reverse SMA connectors
  • Flexible deployment to improve signal transmission and reception
Product codes
  • 14dBi directional operation boosts your signal to a further distance in a specific direction.
  • Features 100cm CFD-200 low loss cable for flexible deployment.
  • RP-SMA Male connector, works with most of access points / wireless routers.
  • Provides easy installation mounting kits.
TP-Link TL-ANT2414A - antenna
Antenna
24 cm x 24 cm x 4 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, wall-mountable, pole mount
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.5 GHz
Gain
14 dBi
Directivity
Directional
Plug and Play, FCC, RoHS
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK WLAN-Antenna 2...
£57.48
