TP LINK WLAN-Antenna 2.4GHz 8dBi Indoor Omni RP-SMA
£5.91
Delivery:
Key features
  • Compliant with 802.11b/g
  • Easy to install and use
  • 8dBi omni-directional gain boosts your signal to a higher range
  • RP-SMA male connector, compatible with most Wi-Fi devices
Product codes
The TL-ANT2408CL 8dBi antenna is ideal for upgrading your wireless access points/routers. It is very easy to use, no configuration or software installation required.
TP-Link TL-ANT2408CL - antenna
Antenna
1.3 cm 29.4 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Indoor
Compatibility
802.11 b/g/n
Frequency Range
2.4 - 2.4835 GHz
Gain
8 dBi
Directivity
Omni-directional
RoHS
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK WLAN-Antenna 2...
£5.91
