TP LINK WLAN-Antenna 2.4GHz 9dBi Outdoor Yagi SMA
£23.19
Delivery:
Key features
  • Complies with 2.4GHz 802.11b/g standards
  • Provides 1m extension cable
  • Complete plug & play instructions
  • Works with all the wireless devices with reverse SMA connectors
  • Flexible deployment to improve signal transmission and reception
Product codes
What This Product Does
Directional Antenna TL-ANT2409A operates in the 2.4GHz band and provides 9dBi directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the RP-SMA female connector guaranteeing wider compatibility with most of the wireless equipments.
Enjoy the benefits of wireless connectivity at greater distances and throughput throughout your indoor wireless zone. No configuration or installation software required .
Easy To Use
Installation of the TL-ANT2409A is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
Product Description TP-Link TL-ANT2409A - antenna
Product Type Antenna
Dimensions (WxDxH) 12 cm x 12 cm x 4 cm
Intended For Wi-Fi
Aerial Placing / Mounting Outdoor, wall-mountable, pole mount, indoor
Compatibility 802.11 b/g
Frequency Range 2.4 - 2.5 GHz
Gain 9 dBi
Directivity Directional
Compliant Standards Plug and Play, FCC, RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK WLAN-Antenna 2...
£23.19
