We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Meet Ultimate Ears MEGABLAST, an incredibly powerful portable Wi-Fi/Bluetooth speaker with big, bassy 360° sound and hands-free voice control. Now with Amazon Alexa built-in, you and your crew can blast tunes, discover new music, order takeout, and more, with just the power of your voice. Do it all at home or on-the-go, even take calls without killing the music whenever connected to Wi-Fi or a mobile hotspot. MEGABLAST is waterproof, rugged, and stunning too - go from cocktail party to the pool party with confidence and style. Just say it to play it with MEGABLAST from Ultimate Ears.
Product Description | Ultimate Ears MEGABLAST - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Dustproof, waterproof, drop-proof | Speaker Type | Active | Frequency Response | 60 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Colour | Green | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 23.7 cm | Dimensions - Diameter | 8.8 cm | Weight | 1.2 kg | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | Yes |
Enclosure Colour | Green |
Speaker System | |
Max Output Level (Max SPL) | 93 dB |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP) |
Transmission Range | 100 m |
Internet of Things (IoT) | |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Speaker: 2 x woofer driver - 2.17" , Speaker: 2 x Passive Radiator - 3.35 x 1.97" , Speaker: 2 x tweeter driver - 0.98" |
Miscellaneous | |
Included Accessories | Power adapter, micro-USB cable |
Compliant Standards | IP67 |
Max Depth of Water Resistance | 1 m |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 16 hour(s) |
Dimensions & Weight | |
Diameter | 8.8 cm |
Height | 23.7 cm |
Weight | 1.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
