Veho 360 WHITE M4 BLUETOOTH SPEAKER
Key features
  • Ultra small and portable with stereo BIG sound
  • Line in port and cable for use with non-Bluetooth devices
  • micro SD slot to play music direct from source
  • Volume and track control on speaker
  • Perfect packet sized portable speaker for travel
Product codes
The 360° M4 Bluetooth Speaker follows on from the successful VSS-006-360BT 360° M3 Bluetooth Speaker but introduces duel 2 x 2.2 w speaker power and includes a microSD card slot and volume/track control.
The 360° M4 Bluetooth Wireless Speaker remains totally portable standing only 6.5 cm high with a diameter of 5.5 cm and contains a 600 mAh rechargeable battery that allows playback of up to 6 hrs. The M4 also ships with a standard 3.5 mm line in cable to use with any standard non Bluetooth device, mini USB charging cable and also a funky protective carry sock.
Sound output on the 360° M4 Bluetooth Wireless Speaker is doubled boosted by two 2.2 watt speakers and for convenience volume and track control are located on the speaker so you can control your music from the speaker whether you are using Bluetooth wireless or the micro SD port located on the speaker.
Veho 360 M4 Bluetooth Wireless Speaker - speaker - for portable use - wireless
Speaker - for portable use
microSD card reader
Speaker Type
Active
Nominal Output Power (Total)
4.4 Watt
Bluetooth
Audio Formats
MP3, WMV (Sound)
Speaker Details
Speaker - stereo x 2 - 2.2 Watt - active
Ice white
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
6.5 cm
Dimensions - Diameter
5.5 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Veho 360 WHITE M4 BLUE...
