Veho DS-1 Charging Dock for iPhone/iPod
£3.82
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Charge and sync your iPhone or iPod with the compact and sturdy MFi DS-1 desktop dock from Veho.
The Veho DS-1 desktop dock is the quick and easy way to charge and sync your iOS device. Simply connect the Veho DS-1 desktop dock via the 1.5metre USB cable to your laptop or PC and place your iPhone or iPod into the built-in MFi Apple approved lightning connector and your device will instantly start charging/synchronising.
The Veho DS-1 desktop charging dock uses the PC or laptops existing power supply to charge your iOS device, and from there you can sync your iPhone or iPod to your iTunes library.
Alternatively, if you just want to add extra power to your iOS device, you can simply plug in the Veho DS-1 to USB power source such as a USB plug.
The DS-1 ships with an Apple certified 1.5m (4.9ft) cable, which is replaceable if you want to implement a much longer cable or switch to micro USB for an Android device.
The micro suction base means the DS-1 sticks firmly to any flat clean surface and adds stability for your iPhone of iPod when it is docked.
The Veho DS-1 is the ideal accessory for any room of the house where you might like to leave your phone to charge. Whether that’s on your office desk, in the kitchen or on your bedside table. The DS-1 is perfect for all users who want a neat a tidy way charge and synchronize your device.
The Veho DS-1 is compatible with the iPhone 5/5S/6/6S and iPod Touch 5th/6th Generation.
Key Features
Charge and sync desktop dock for iPhone/iPod with the built-in 1.5m MFi Apple approved lightning connector Micro suction base avoids the dock moving around Automatically sync your device with your iTunes library Ideal for business users, students or for neatly storing your iOS device while charging Compatible with iPhone 5/5S/6/6S and iPod Touch 5th/6th Generation
Box Contents
DS-1 Charging Stand 1.5m MFi Apple Lightning Cable Allen Key Quick Start Guide (English, French, German, Italian, Portuguese, Spanish, Russian, Japanese, Chinese).
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho DS-1 Charging Doc...
£3.82
