Marketing description is not available.
Product Description | Veho Kasa - LED light bulb | Light Bulb Type | LED light bulb | Socket Type | E14 | Wattage | 5 W | Wattage Equivalent | 7.5 W | Light Bulb Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours | Luminous Power | 300 lumens | Dimmable | Yes | Voltage Required | AC 85 - 245 V | Frequency Required | 50/60 Hz |
Light Bulb | |
Socket Type | E14 |
Wattage | 5 W |
Dimmable | Yes |
Lifetime | 15000 hours |
Features | Android compatible, iOS compatible, controlled via Bluetooth 4.0 Low Energy, remote controlled |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Bluetooth Low Energy (LE) |
Dimensions & Weight | |
Diameter | 50 mm |
Length | 101 mm |
