Veho MUVI 3 CUP PRO SUCTION MOUNT
£12.38
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 3 secure suction cups each with own locking and quick release mechanism for super tight mount
  • Tilting suction cups for mounting on uneven flat surfaces such as car KeySellingPointswork or boat decking
  • Small and large adjustable mounting arm with swivel head and standard 1/4-inch tripod mount
  • Compatible with all MUVI HD and other lesser action cameras as well as regular cameras
  • Perfect for all motorsports, speedboats, helicopters and planes
  • Stock Status: In Stock
Product codes
The MUVI universal triple cup suction mount is designed for professional and prosumer use on all flat surfaces that might be moving at high speeds such as vehicles, boats or aircraft. Each suction cup is fitted with its own suction lock and quick release mechanism and has an adjustable design so it can be mounted at different angles to fit many different scenarios or mounting options.
This mount ships with 2 sized adjustable arms for mounting your MUVI, action cam or camera. The small arm measures 9 cm (3 inches) and the larger arm 12 cm (5 inches) and both allow swivel head connection to the MUVI cradle or a universal tripod mount.
Product Description Veho MUVI 3 Cup Pro Suction Mount - support system - suction mount
Product Type Support system - suction mount
Designed For Muvi Atom, HD, HD10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho MUVI 3 CUP PRO SU...
£12.38
