Veho MUVI 3M K-Series Flat Adhesive Mount (pack of 3)
£1.99
42 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Industrial strength 3M adhesive to secure your MUVI
  • Can be easily removed by applying heat, such as a hair dryer
  • MUVI 3M Flat Adhesive Mounts are waterproof
  • Stock Status: Clearance
Product codes
Pack of 3 x MUVI 3M Flat Adhesive Mounts for use with your MUVI or MUVI HD camcorder. These mounts allow you to mount your MUVI camcorder securely to any flat surface. They will hold your camcorder securely in place but can easily be removed by applying heat, such as using a hair dryer.
Product Description Veho MUVI 3M Flat Adhesive Mounts support system - adhesive mount
Product Type Support system - adhesive mount
Designed For Muvi Atom, HD, HD10, Pro DV
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho MUVI 3M K-Series...
£1.99
