Veho Muvi Drivecam Quad HD Dashcam with GPS, Wifi and App
£205.04
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Quad-HD video quality 1080p@60 fps
  • GPS tracking with route mapping software
  • Automatically turns on and starts recording when driving, stops when you turn the engine off
  • Type: Dashboard camera
  • Stock Status: In Stock
Product codes
The Muvi Drivecam with GPS tracking captures your journey in 1080p HD footage that can be viewed, via the App, on your smartphone, tablet or PC. Fully equipped with motion detection for automatic start/stop recording and a G-Force sensor, so should your car be involved in a collision, your files will be automatically protected.
HD QUALITY
Quad-HD video quality 1080p@60fps
GPS TRACKING
AUTO START/STOP
DEDICATED APP
Reviewed footage via the App, on your smartphone or tablet
MEMORY
Micro SDHC up to 128GB, not included
Product Description Veho muvi VDC-001-KZ1-F - dashboard camera
Product Type Dashboard camera - 1080p - widescreen
Memory Card Slot microSD card
Sensors Motion sensor
Wireless Interface Wi-Fi
Sensor Resolution 2.13 MP
Max Video Resolution 1920 x 1080
Lens System Wide-angle lens f/2.0
Focus Adjustment Focus free
Display LCD display - 3"
Real-Time Locations GPS
Incident Detection G-Sensor
Supported Battery 1 x 900 mAh
Dimensions (WxDxH) 11.44 cm x 3.7 cm x 7.19 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho Muvi Drivecam Qua...
£205.04
