Veho MUVI EXTENDED POLE/BAR MOUNT
£3.99
Delivery:
Key features
  • Extended arm for more scope of vision
  • Ideal for self-portrait filming from handle bars
  • 2 fully adjustable ratchet pivots to mount the MUVI or MUVI HD at any angle
  • Ideal for mounting on bikes and motorbikes
Product codes
The MUVI Extended Pole Mount is designed to give users a better field of vision which is ideal for self-portrait filming with the help of the strong and robust extended arm built to any tube diameter ranging between 0.9 mm-23 mm.
The MUVI Extended Pole Mount has 2 ratchet pivots that are fully adjustable to allow you to angle your MUVI or MUVI HD any way you want. The MUVI Extended Pole Mount comes with a tripod mount but is also compatible with the cradle mount that comes with your MUVI or MUVI HD camera. It can be mounted anywhere from a bike frame or handlebars to car roll bar or cages. The mount is also ideal for motorbikes for viewing over the wind deflector to ensure that you don't compromise on quality of the footage.
Product Description Veho MUVI Extended Pole/Bar Mount support system - bar mount
Product Type Support system - bar mount
Placing / Mounting Handlebar, pole mount
Designed For Muvi Atom, HD, HD10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho MUVI EXTENDED POL...
£3.99
