Veho MUVI LARGE POLE/BAR MOUNT
£2.31
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fully adjustable pole/bar mount with a diameter ranging from 16-58 mm
  • Perfect for clamping to any part of a bike, car roll bars and ski/surf/snowboard racks
  • Ships with a tripod mount for compatibility with MUVI and MUVI HD waterproof cases
  • Strong robust redesign built to withstand hard and fast movements
  • Stock Status: In Stock
Product codes
Attach your MUVI or MUVI HD camera to larger handle bars, roll bars, boat masts or any diameter tubes ranging from 16 mm to 58 mm. The Large Pole/Bar Mount is ideal for clamping almost anywhere and is completely compatible with the MUVI cradle mount that comes with your MUVI or MUVI HD camera or using with the tripod mount and waterproof case.
The Large Pole/Bar Mount is perfect for mounting ski/surf/snowboard racks, roll cages/bars, bike handlebars and bike frames. The Large Pole/Bar Mount ships with a tripod mount and 2 rubberized bands to help secure your mount and prevent damage so you can position your MUVI camera at any angle you want.
Product Description Veho MUVI Large Pole/Bar Mount support system - pole mount
Product Type Support system - pole mount
Designed For Muvi Atom, HD, HD10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Veho MUVI LARGE POLE/B...
£2.31
