Veho PEBBLE™ Explorer 8400mAh Portable Charger for Tablet / S...
CLEARANCE
PRICE DROP
Veho PEBBLE™ Explorer 8400mAh Portable Charger for Tablet / Smartphone
CHARGE 2 DEVICES AT THE SAME TIME WITH DUAL USB!
£29.98
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Powerful 8400 mAh portable and rechargeable battery for tablets, smartphones and USB rechargeable devices
  • Dual 2.1 amp USB outputs designed to charge tablets and smartphones fast and efficiently
  • Digital LED indicator giving exact percentage charge
  • Auto shutoff mode to protect against short circuit, over-current, over-charging, and over-discharging
  • Type: Charger
  • Size: 8400mAh
  • Stock Status: In Stock
Product codes
The PEBBLE Explorer has a large 8400 mAh capacity and dual USB port designed to enable charging of 2 devices at any one time. With a 2.1 A output the PEBBLE Explorer is designed to charge tablets in the most efficient way. This means that your tablet power is replaced as quickly as possibly when you're low on charge and away from a mains source. Don't worry if your smartphone is also low on charge because the Explorer's dual port design means it's capable of charging 2 devices at the same time. The powerful 8400 mAh battery can give most tablets a complete full charge and most smartphones up to 5 charges.
The stylish blue LED power indicator means you can keep a close eye on the Explorer's exact capacity when charging your devices and also when you are recharging your Explorer. An long hour mains charge to the Explorer will give your portable devices hours of additional usage while you are away from the mains which makes it the perfect companion for camping, trekking, festivals as well as business users who easily drain their portable devices during a long busy day.
Product Description Veho Pebble Explorer - external battery pack
Product Type External battery pack
Dimensions (WxDxH) 7.5 cm x 9.2 cm x 2.3 cm
Weight 192 g
Voltage Required 5 V
Voltage Provided 5 V
Battery 8400 mAh
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho PEBBLE™ Explorer...
£29.98
