Veho PEBBLE™ Verto Portable Charger 3700mAh - Orange
Key features
  • Will charge most popular mobile devices including smartphones, Blackberry, Samsung, Nokia, Sony, gaming and USB charged devices
  • Mini credit card sized portable design
  • Auto shutoff mode to protect against short circuit, over-current, over-charging and over-discharging
  • Powerful 3700 mAh portable battery charger
  • Just over 2-1/2 full charges of most smartphones
Product codes
The powerful Veho PEBBLE™ Verto portable battery charger is the must have accessory to keep all your mobile devices full of charge. It packs a 3700mAh which is over 2 times the regular battery of the Apple iPhone or Smartphone which means it will keep your devices on the go and you won't have to worry about running low on juice.
The PEBBLE™ Verto is perfect for festivals, camping trips, travelling abroad or as an emergency power pack for those busy days when your devices battery just can't keep up. The PEBBLE™ Verto will charge almost any portable device with connectors for the most popular Smartphones/USB charged devices/Veho MUVI™ and 360° range.
Simply charge your PEBBLE™ Verto up via USB and use the various adapters to keep all your mobile devices charged up. The PEBBLE™ Verto has a new smaller 'credit card' sized footprint perfectly portable and comes with 4 tips, charging cable and funky neoprene pouch to carry it all.
  • Will charge most popular mobile devices including Smartphones, Blackberry, Samsung, Nokia, Sony, gaming and USB charged devices
  • Mini credit card sized portable design with included neoprene carry case. Perfect for handbag or pocket (3.5in x 2.5in x 0.5in)
  • Powerful 3700mAh portable battery charger (up to 1000 extra standby hours or 90 hrs extra music playback)
  • Just over 2 ½ full charges of most Smartphones
Product Description Veho Pebble Verto - power bank
Product Type Power bank
Dimensions (WxDxH) 6.5 cm x 9 cm x 1.4 cm
Weight 92.6 g
Colour Orange
Output Connector Type USB
Voltage Required 5 V
Voltage Provided 5 V
Battery - 3700 mAh
Standby Time 1000 h
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho PEBBLE™ Verto Por...
