Top-up your essential devices on the move without the inconvenience of finding a power outlet, thanks to the improved emergency rechargeable Pebble Ministick from Veho. With a soft-touch finish, the Veho Pebble Ministick also has a handy loop, ideal for either putting on a set of keys.
Product Description | Veho Pebble Ministick power bank - Li-Ion | Product Type | Power bank | Dimensions (WxDxH) | 10.25 cm x 2.28 cm | Weight | 62 g | Colour | Black | Output Connector Type | USB - on cable: Micro-USB | Voltage Required | 5 V | Voltage Provided | 5 V | Battery | Lithium Ion - 2200 mAh | Cables | Micro-USB to USB cable |
General | |
Width | 10.25 cm |
Depth | 2.28 cm |
Weight | 62 g |
Enclosure Colour | Black |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Output connectors | 4 pin USB Type A |
Detachable Cable Connector Type | Micro-USB Type B |
Max Electric Current | 1 A |
Battery | |
Technology | Lithium Ion |
Capacity | 2200 mAh |
Features | LED power meter, built-in key ring, Tacton rubber finish |
Miscellaneous | |
Included Accessories | USB charging cable |
Cables Included | Micro-USB to USB cable |
Compliant Standards | EMC, RoHS |
