Veho Pebble P1 10400mAh Portable Battery Pack Charger
£26.02
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Large portable power bank with dual USB outputs to charge 2 devices simultaneously
  • Fast 2.1 A charging designed to charge tablets, smartphones, portable USB devices fast and efficiently
  • Fast and futureproof charging with USB-C compatible input for USB-C devices and cables
  • Ergonomic design with digital LED indicator giving the exact percentage available
  • Device Type: Smartphone
  • Type: Power Bank
  • Stock Status: In Stock
Product codes
The Pebble P-1 from Veho has a large 10,400mAh capacity with dual USB ports designed to enable charging of 2 devices simultaneously.
The fast 2.1A charging output has been designed to charge tablets, smartphones, Sat Nav’s, GPS’s trackers and other portable USB devices fast and efficiently.
The Pebble P-1 allows you to use your own charging cable to charge up your devices’ and is capable of charging the popular smartphones such as the iPhone 7 up to 5 times and the Samsung Galaxy S8 up to 3 times.
With a USB-C input charging port, the Pebble P-1 is compatible and future proof for new USB-C devices and cables, so you won’t have to update your power bank when you update your smartphone, tablet or portable device.
The Pebble P-1 incorporates Pebble stylish ergonomic design, which has been popular with power bank users. The power bank features a smooth matte black, Tacton rubber touch finish and a digital LED display indicator giving the exact percentage available.
Designed in the UK, the Pebble P-1 is packed with superior quality lithium-ion battery cells, ensuring that you get the true mAh rating and conform to all safety marks and regulations such as CE, RoHS and EMC.
The Pebble P-1 comes with micro-USB to USB-A charging cable, a protective carry pouch and multi-lingual user manual.
Key Features
  • Large 10,400mAh portable power bank with dual USB outputs to charge 2 devices simultaneously.
  • Fast 2.1A charging designed to charge tablets, smartphones, portable USB devices fast and efficiently
  • Fast and futureproof charging with USB-C compatible input for new USB-C devices and cables
  • Superior quality lithium-ion battery that conforms to all safety marks such as CE, RoHS, and EMC.
Box Contents
  • Veho P-1 Power Bank
  • Micro USB to USB-A Charging Cable
  • Protective Neoprene Pouch
  • Multi Lingual User Manual (English, French, Spanish, German, Italian, Portuguese, Russian, Chinese & Japanese)
Product Description Veho Pebble P-1 power bank
Product Type Power bank
Dimensions (WxDxH) 11.5 cm x 7.8 cm x 2.55 cm
Weight 260 g
Output Connector Type USB
Voltage Required 5 V
Voltage Provided 5 V
Battery - 10400 mAh
Cables Micro-USB to USB cable
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho Pebble P1 10400mA...
£26.02
