Veho SAEM optional handlebar mount for S6 water resistant case
Key features
  • Secures the cellular phone to poles / bars or handlebars
  • Fully adjustable clamp
  • Rubberized teeth to ensure no movement when mounted
  • Quick release locking plate to attach and remove the phone from the mount
  • Ideal for bikes, boating, sailing and other outdoor pursuits
Product codes
This clamp mount is the ideal accessory for mounting your cellular phone safely and securely to handlebars or bars. The strong and robust clamp with rubberized teeth will firmly hold the phone in place. It is easy to position and allows you to use your device handsfree. This mount accessory is versatile and ideal for biking, boating, sailing, outdoor pursuits, roll bars and roll cages.
Product Description Veho SAEM - clamp mount
Product Type Clamp mount
Intended for Mobile phone
Designed For Samsung Galaxy S6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho SAEM optional han...
