Veho Smartfix 14 Megapixel Negative Film and Slide Scanner
FREE DELIVERY
£99.99
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Convert slides and negatives into digital images
  • Stand-alone portable design with no computer or software required
  • Small/lightweight with built-in TFT LCD screen
  • Instant preview and built-in auto-exposure, color balance and other image enhancements
Product codes
Convert all your old 135 slides and 135/110/126 negatives into digital images with the Smartfix 14 megapixel scanner from Veho.
Transferring your negative film and slides and negatives direct to SD card makes it ideal for editing, archiving or for sharing old photographs with your family and friends.
The Veho Smartfix is a complete stand-alone scanner with 2.4" preview/review LCD screen with a removable lithium-ion rechargeable battery and comes with a USB charging cable, making this scanner completely portable.
The fast one touch scanning makes it easy to bring those old pictures back to life. The instant preview and built-in auto-exposure/colour balance ensures that the pictures come out their absolute best.
The Smartfix scanner is PC and Mac compatible and supports up to 32GB SDHC / SD card not included.
Key Features
  • Convert 135 slides and 135/110/126 negatives into digital images
  • Small/lightweight with built-in 2.4" TFT LCD screen, one touch scanning and Tacton rubber touch finish
  • Instant preview and built-in auto-exposure, colour balance and other image enhancements
  • Optional USB connection compatible with Mac/PC for easy file transfer
Box Contents
  • Veho Smartfix Scanner
  • 135 Slider Tray
  • 135 Negative Tray
  • 110 Negative Tray
  • 126 Negative Tray
  • Cleaning Brush
  • USB-A to Mini-B USB Cable
  • 3.5mm Jack to yellow RCA Cable
  • Lithium-ion Battery
  • Quick Start Guide
Veho VFS-014 Smartfix - film scanner (35 mm) - desktop - USB 2.0
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Scan Element Type
CMOS
Max Supported Document Size
Film 135 (35mm)
Supported Document Type
Slides, film
1 x Lithium Ion
14.4 cm x 11.6 cm x 11.9 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho Smartfix 14 Megap...
£99.99
