Veho V-1 USB Battery Charger
£12.94
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Anti-reverse charging and over-charging protection with LED display indicator
  • Use at home or at work through a computer or a USB plug
  • Stock Status: In Stock
Product codes
The V-1 features anti-reverse charging and over-charging protection with a helpful LED display indicator to prevent any damage to the batteries or the USB battery charger and show the charging status.
Charge your batteries anywhere thanks to the included USB-A to micro-USB cable, perfect for charging at home or at work through a USB mains plug or computer. Alternatively, you can charge your V-1 battery charger on the go through your laptop or a portable power banks.
The V-1 Pebble USB battery charger is the must have accessory E-Cigarettes, flashlight and other products that use 18650 or compatible batteries.
Designed in the UK, the Veho V-1 USB battery charger confirms to all safety marks such as CE, EMC and LVD.
The versatile V-1 USB battery charger is compatible with a wide variety of batteries, such as 18650, 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18700, 22650, 20700, 21700, 22700, 25500, 26650 and 26700 batteries.
*Batteries not included
**Not compatible with rechargeable AA or AAA batteries
Product Description Veho V1 battery charger
Product Type Battery charger
Voltage Required 5 V
Cables Micro-USB to USB cable
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho V-1 USB Battery C...
£12.94
