Veho VAA-010 Triple USB 5V 5.1a Car charger
£7.11
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Triple USB car charger with powerful quick charge
  • Small, sleek aluminum design ideal for short or long distance car journeys such as business commutes, school runs or car holidays
  • Ideal for smartphones, e-cigarettes, tablets, or any other USB rechargeable device
  • Safety design feature to detect correct amperage and stop overheating or overcharging of your mobile device
  • Type: Charger
  • Size: 5.1 Amp
  • Stock Status: In Stock
Product codes
Charge your smartphone, tablet or any other USB device simultaneously with the triple travel car charger from Veho. The Veho charger works with standard vehicle sockets and has 3 separate USB ports, meaning that not only can you charge more than one device at the same time, but the 2.1 A output will safely charge up your smartphone device quicker than any standard USB travel charger. As well as smartphones, the powerful output from the Veho will charge devices such as e-cigarettes, GPS, tablets, e-book readers, PDAs, portable speakers, or any other USB rechargeable device. The small, sleek aluminum design of the Veho in car charger means that it will look good in any car. The Veho charger is the must have accessory for anyone who spends a lot of time in their car, and is ideal for any short or long distance car travel journeys such as work commutes, school runs or car holidays. With built-in detection functionality to detect the correct device amperage and also safety features that will stop overheating, overcurrent and overcharging, your mobile device is protected whatever its specifications. Charging will automatically stop when your device is full.
Product Description Veho VAA-010 car battery charger
Product Type Car battery charger
Colour Space grey
Output Connector Type USB
Voltage Required 12 - 18 V
Power Device Details - 4 pin USB Type A - 5 V - 1 A , - 4 pin USB Type A - 5 V - 2 A , - 4 pin USB Type A - 5 V - 2.1 A
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VAA-010 Triple US...
£7.11
