Veho VCC-A035-WPC 100m Waterproof case for Muvi K-Series only
Key features
  • Waterproof to depths of 100 m
  • Fitted with 2 buttons meaning fully operational for filming and photography
  • Fitted with standard tripod mount for mounting purposes
  • Waterproof access point to enable access to power and microphone ports when used outside the water
Product codes
The MUVI K-Series waterproof case allows your camera to be fully functional for both filming and photography. Simply fit your camera into the waterproof case and your camera will be protected from bumps and shocks as well as waterproof down to 100 m. While fitted in the waterproof case the K-Series remains functional with 2 buttons for operation of filming and photography. The waterproof case has a standard tripod mount and a port access point for power and microphone access.
Muvi K-Series - marine case camcorder
Marine case camcorder
Underwater Depth
Up to 100 m
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VCC-A035-WPC 100m...
