Veho VCC-A041-MBK 3M Mounting bracket kit for Muvi
£1.18
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Additional mounting options for your MUVI K-Series camera for helmets or flat surfaces
  • Industrial strength 3M adhesive to secure your MUVI K-Series camera
  • Can be easily removed by applying heat, such as a hair dryer
  • MUVI K-Series 3M mounting bracket kit is waterproof and robust and ideal for most action sports
  • Stock Status: In Stock
Product codes
The 3M mounting bracket kit for the MUVI K-Series range includes a curved and a flat 3M adhesive mount.
The 3M mounting bracket kit will allow you to secure your MUVI K-Series camera to any flat or curved surface.
The curved mount is designed for mounting to helmets of all kinds while the flat mount is perfect for any flat surface. They are compatible when the K-Series is in the waterproof housing or when the MUVI K-Series is in the cradle on the flat tripod mount.
The strong 3M adhesive pads are waterproof and robust, and hold your MUVI securely in place but can also easily be removed by applying heat, such as a hair dryer.
Product Description Veho MUVI 3M MOUNTING BRACKET KIT support system - adhesive mount
Product Type Support system - adhesive mount
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VCC-A041-MBK 3M M...
£1.18
