The 3M mounting bracket kit for the MUVI K-Series range includes a curved and a flat 3M adhesive mount.
The 3M mounting bracket kit will allow you to secure your MUVI K-Series camera to any flat or curved surface.
The curved mount is designed for mounting to helmets of all kinds while the flat mount is perfect for any flat surface. They are compatible when the K-Series is in the waterproof housing or when the MUVI K-Series is in the cradle on the flat tripod mount.
The strong 3M adhesive pads are waterproof and robust, and hold your MUVI securely in place but can also easily be removed by applying heat, such as a hair dryer.
Product Description | Veho MUVI 3M MOUNTING BRACKET KIT support system - adhesive mount | Product Type | Support system - adhesive mount |
General | |
Product Type | Support system |
Tripod | |
Supported Devices | Action camera |
Support Type | Adhesive mount |
Kit Content | |
Kit Content | (1) x curved surface adhesive mount , (1) x flat surface adhesive mount |
