Veho VCC-A043-EHM Extended helmet mount for Muvi K-Series
£11.36
Delivery:
Key features
  • Extended arm for more scope of vision
  • Ideal for self-portrait filming from any smooth flat surface
  • Strong 3M flat adhesive base pad
  • Perfect for car bonnets or any kind of boarding sport like snowboard, surf board, wake board, kite board
Product codes
The MUVI K-Series extended flat surface mount has a strong robust arm and 3M sticky base designed for raised elevation field of view when filming.
The extended flat surface mount is designed for an easy and secure fitting so you can capture all the action, thanks to the strong 3M adhesive base pad, which is perfect for mounting on any smooth flat surface.
The strong and robust mount comes with a twist and lock rotating arm, which ensures that the mount doesn't move when performing fast movements.
Should you wish to remove or replace the extended flat mount, by applying heat such as a hairdryer, the mount is easy to peel off and re-stick.
This mount raises the elevation of the camera to give that floating effect and move the camera away from the surface it is mounted on. This can be useful for flat surfaces such as car bonnets or any kind of boarding sport like snowboard, surf board, wake board, kite board.
Product Description Veho MUVI EXTENDED FLAT MOUNT support system - adhesive mount
Product Type Support system - adhesive mount
Placing / Mounting Surface mountable, surfboard, skateboard, snowboard
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VCC-A043-EHM Exte...
£11.36
