Veho VEP-008-Z8 360 Designer headphones with flex cable
£30.79
Delivery:
Key features
  • 40mm noise isolating technology with super soft leather ear pads & adjustable headband for ultimate comfort
  • Foldable design that comes with a 130cm Flex 'anti' tangle cord system, perfect for travel
  • Contemporary design with stylish brushed aluminum finish and debossed Veho logo
Product codes
The headphones come with built-in noise isolating technology, soft leather ear pads and a contemporary aluminum look, designed to stand out from the others.
The Z8 headphones are fully compatible with all devices such as MP3 players, iPhone, iPad, laptops or any device which uses a standard 3.5mm output jack. Alternatively, connect it up to the SAEM S4 to turn them into wireless Bluetooth headphones.
The 40mm noise isolating technology will decrease the surrounding noise pollution to allow you to enjoy and listen to your music the way you want. The super soft leather ear pads are designed for your comfort and the adjustable headband makes these headphones ideal for any head size.
The foldable sleek and stylish design comes with a detachable 130cm flex flat 'anti' tangle cable that can be easily stored in the protective carry case, perfect for traveling or commuting.
Product Description Veho Z8 - headphones
Product Type Headphones - wired - 3.5 mm jack
Recommended Use Portable electronics
Headphones Form Factor Full size
Foldable Yes
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 92 dB
Impedance 32 Ohm
Noise Isolating Noise isolating
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VEP-008-Z8 360 De...
£30.79
