Veho VPP-901-MSB DS-1 Charge and Sync Docking Station for And...
Veho VPP-901-MSB DS-1 Charge and Sync Docking Station for Andriod
£15.74
Delivery:
Product codes
The Veho DS-1 desktop dock is the quick and easy way to charge and sync your smartphone. Simply connect the Veho DS-1 desktop dock via the 1.5metre USB cable to your laptop or PC and place your Android Smartphone into the built-in micro USB connector and your device will instantly start charging/synchronising. The Veho DS-1 desktop charging dock uses the PC or laptops existing power supply to charge your device and also synchronise music and files. Alternatively if you just want to add extra power to your device you can simply plug in the Veho DS-1 to USB power source such as a USB plug. The micro suction base means the DS-1 sticks firmly to any flat clean surface and adds stability for your smartphone when it is docked. The Veho DS-1 is the ideal accessory for any room of the house where you might like to leave your smartphone to charge. Whether thats on your office desk in the kitchen or on your bedside table. The DS-1 is perfect for all users who want a neat a tidy way to charge and synchronize your device. The Veho DS-1 is compatible with any smartphone with a centrally located micro USB port.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho VPP-901-MSB DS-1...
£15.74
